  Thread 464/63
Hydrofluoric acid substitute
We operate plating facilities in several parts of the world plating nickel/silicon carbide deposits onto high silicon aluminum castings. Typically, during the pre-treatment, we "de-smut" (acid etch) using a nitric acid/hydrofluoric acid solution prior to zincating.
We are about to open a new facility in a location where hydrofluoric acid acid is not available, so I need to find a substitute that will work as well as (or better than) HF.
Any ideas please?
Geoff Slater
plating shop owner - Weston-super-Mare, England
publicly reply to Geoff Slater
Do a search of this site for ammonium bifluoride for the amount to equal the HF. Infinitely more safe than HF, but it is an additive to nitric acid or sulfuric acid for etching.
publicly reply to James Watts
Depending on the amount of Si you are talking about, you might try a Ammonium Bifluoride/Nitric Acid mixture. If memory serves me correctly (I don't work with cast Al anymore) I believe we used 8oz/gal concentration.
Marc Green
Marc Green
anodizer - Boise, Idaho
publicly reply to Marc Green
These guys are right - use ammomium bifluoride. It can be obtained from most of the better chemical supply houses in the UK
publicly reply to Trevor Crichton
Hydrofluoric acid burns left and right hands, two views, burned index fingers
Never use HF anywhere unless trained!
If you do, you MUST have the antidote gel on hand for instant use!
Calcium Gluconate
for HF acid burns
calcium_gluconate
Geoff
All good advice
Just make sure that any spec you are operating permits bifluoride.
Remember, it is much safer to handle but you still need calcium gluconate gel available and appropriate first aid training.
publicly reply to Geoff Smith
Hi my name is Frank Klodner I work in a plant that makes car care products and am looking for a HF replacement, we use it as a wire wheel cleaner but with everyone going green would like to go green myself.
Frank Klodner
Car care Products - Toronto ontario
May 20, 2009
publicly reply to Frank Klodner
