Thread 463/60
Cleaning - Pure Nickel
For my study work, I have to clean the Pure (99.8%) Nickel. I want to remove the Moisture, other contaminations and foregin materials. Pl give a solution to do the same with out lose in purity.
S.P.MadavanProduct designer - Bangalore, India
publicly reply to S.P.Madavan
Maybe I'm not fully understanding the problem, Madavan, but it seems that you can either bead blast it or chemically clean it. If you chemically clean it, what you need to do would depend on the nature of the soils and contaminants, but probably scrub with pumice ⇦ this on eBay or Amazon [affil links] and water, then rinse with isopropyl alcohol ⇦ this on eBay or Amazon [affil links] . If that's still too much water, dry it in a vapor degreaser. Good luck.
publicly reply to Ted Mooney
Do not dry parts in a halogen based vapor degreaser unless you want a severely pitted unit that will cost a fortune in stabilizer breakdown and eventual replacement of the unit.
James Watts- Navarre, Florida
publicly reply to James Watts
I'll concede that drying parts in a vapor degreaser creates HCl, which is bad for the degreaser, James. But it has long been a common procedure for electronic contacts and other parts of complex shape where contaminant-free drying is otherwise problematic; and some shops have dedicated units that are used exclusively for drying.
