Thread 462/08
Remove seal on anodized aluminum without damaging dye
Q. We are developing a process for reworking stained anodized aluminum hardware. We need to remove the nickel acetate seal without damaging the color and sometimes silkscreening. Once clean we will reseal.
Bob HeimannProduct Designer - Centralia, Missouri
publicly reply to Bob Heimann
A. Hi, Bob. Do you realize that a nickel acetate seal is not a topcoat like lacquer, but involves swelling the pores in the anodized aluminum so that dye and dirt can no longer enter or leave? In this context what does removing the seal really mean to you? If it means reopening the pores, I think it's hopeless, but would like to hear more myself.
publicly reply to Ted Mooney
2007 You really need to define stained. - Navarre, Florida publicly reply to James Watts I think Ted said the same thing, but here is the way I say it. Once you have hydrated the aluminum oxide molecule which is imbedded with dye , then you cannot de-hydrate the molecule without damaging the dye. You are doomed to completely stripping and starting over. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() 2007 publicly reply to Robert H Probert |
I'm trying to install strain gauges to some anodized aluminum parts (MIL-A-8625, Types II and III, Class 1). I've been told that the anodization doesn't need to be removed, but the sodium dichromate sealant does.
Is there a way to easily remove the sealant WITHOUT removing the anodized coating or damaging the parts? The strain gauge vendor recommends "household cleaner," but that's ambiguous.
Thank you!
- Sunnyvale, California, USA
September 1, 2017
publicly reply to Jason December
