Anodizing a second color into a laser etched pattern
Q. Did you figure out how to Two Tone an anodizing project? If you use the acid bath to do the first anodized color then use a laser to add a design. If you go for another Acid bath will it remove the first layer of anodizing?
LPH HartHOBBY - Phoenix Arizona
December 29, 2021
A. Hi LPH. If you just want one color plus black, you can anodize and dye then laser mark. If you want two actual colors, with or without additional black laser marking, please see topic 48706 for some beautiful examples.
December 2021
Q. I am currently building custom CNC wristwatches from 6061 Aluminum. The overall concept is to provide a watch band that is decorated with laser etchings or two tone anodizing without masking. I will be anodizing the case and metal band. However, I would like to laser mark the bands and then apply a different anodized color to the etched design.
Q. Is this possible? If the laser can mark down to bare metal, would another dyeing step fill those bare metal spots in with color?
I would appreciate any insight into twice anodized aluminum.
Kind regards,
Nate Halleehobbyist - Minneapolis, Minnesota
The Sulfuric Acid Process"
by David LaPlantz
or eBay or
A. "Artists Anodizing Aluminum: the Sulfuric Acid Process" by David LaPlantz is a very good book on that subject. Next webpage can be useful too- asuwlink.uwyo.edu/~metal/anodizing2.html
Hope it helps and good luck!
Ed. note Sec. 2021: Sorry, that website is no longer available.
I appreciate the reply Goran. I will take a look at the reference info provided. With any luck I will find what I am looking for as it pertains to laser marking and post anodize decorating.
Q. Is it possible to laser mark bare (before anodizing) 6061 aluminum with either a dark or light colored marking and then anodize the surface around the laser marking? In other words, will the laser marked area be ghosted or different in tone when the whole part is finally anodized in color? Or will the acid bath remove traces of the laser marking?
As you can see I am searching for a way to achieve the effect pictured in this post.
Has anyone tried this before?
Thank you in advance,
A. Hi
I know you can use a product called Ceramark which you spray or paint on the aluminum prior to laser engraving the aluminum. In simple terms the laser burns the Ceramark and creates a reaction in the surface of the aluminum. You can't scratch it off. This process only allows for black to be applied. This might show through a thin pale anodize colour if the anodize preparation doesn't remove it. I've just started looking into doing a similar process on product I'm developing.
Good luck
- Brisbane, Australia
July 14, 2011
