Does cadmium plating on aluminum require a nickel strike first?
We do not plate cadmium but I was wondering if cadmium can be plated directly on aluminum? Is a nickel underplate or electroless nickel plate usually plated first to get good adhesion. We usually apply nickel as an under plate when we plate gold on aluminum.
Jon WernerEngineer Plater - Orlando, Florida, USA
Preferred activation for aluminum and its alloys is a zincate immersion plating cycle (double or even triple). Neutral or slightly alkaline nickel solutions are sometimes used with success though.
