No passwords, No popups, No cost, No AI:
we earn from 'affiliate link' purchases, making the site possible
Sound technical content, curated with aloha by
Pine Beach, NJ
Inconsistent plating thickness with Magni 594 on flat surfaces?
We are a manufacturer of cold formed fasteners and based in Australia. We need to plate an M8 bolt with Magni 594 which has a square flat head - 0.70" x 0.70" x 0.08". The tolerance on the flat head is critical. We need to meet the DBL spec 9440.40 and our Magni approved plater is using Magni 594 but the plating thickness varies greatly (Magni say 12-18 microns) however as the parts touch edge to edge and sometimes back to back the plating finish is imperfect and the plating thickness can range up to 50 microns when measured over the imperfections. Has anyone experienced this before or haver any suggestions as to how to get an even plating coating?
461261
Reject - Parts against mesh during plating
461262
Reject - Parts laying edge to edge
461263
Reject - Parts has finish imperfection on edge
461264
Reject - Parts stuck back to back
Andrew C [last name deleted for privacy by Editor]
User of metal finishing services - Sydney, NSW, Australia
