Cleaning a classic cast iron weigh scale
Hi,
I have an old cast iron Salter's NO 50 scale with a brass face that needs some cleaning. It was used daily in the restaurant I work at but now the boss has gone digital so I have acquired the scale and would like to clean it up. What should I use that will remove the built on grime without affecting the working mechanisms inside.
Thank you for any answers
hobbyist - Blind River, Ontario, Canada
June 18, 2008
Hi, Lorraine.
Any brass that you can get to can be cleaned with a brass/copper polish. There are a hundred brands but Revere Copper Cleaner ⇦ this on eBay [affil links] seems to be good balance between fast-acting and leaving that warm glow.
For the cast iron parts, I think I'd use light Machinery Oil [affil links] or maybe WD-40 ⇦ this on eBay or Amazon [affil links] . You don't want to use anything that removes all the oil or it will quickly rust.
