Thread 459/27
Mold Finish - NTMA Standard, converting NTMA to Ra, RMS for silicone parts
Hello,
My name is Nick. I have a question regarding surface finish for molds and associated silicone parts that come from those molds. I have a print that calls out an NTMA surface finish for a mold and also calls out an NTMA finish for the silicone parts that come out of that mold. I am familiar with Ra and RMS surface finish and can't find any correlation between NTMA and Ra or RMS. Is there a conversion formula or table that goes between NTMA and Ra or RMS that you as finishers know of? Thank you for your time.
product development engineer - Santa Barbara, California
publicly reply to Nicolas Welche
I don't have a direct answer.
The National Tooling and Machining Association has several publications on moldmaking. 'Introduction to Moldmaking' includes "surface finishes for molds; fabrication materials for molds; mold problems and solutions; mold repair techniques-welding; glossary of terms and tables-conversion."
They also have a Mold Finish Specimen Kit: "A book-sized molded case that opens to reveal 29 different surfaces produced by various finishing processes." www.ntma.org
- Goleta, California
publicly reply to Ken Vlach
I agree with Ken. The best (and perhaps the only) conversion you will get is from their surface comparator and your own eyes. Inner surfaces of molds normally do not lend themselves to profilometer reading (designed for flat surfaces), so that's why, in the plastic industry we all use visual comparators mostly for the metallic surfaces but for the molded parts as well.
publicly reply to Guillermo Marrufo
Thanks for the response. I have the kit from NTMA, and as you mentioned it appears that visual comparison is the only option.
Nick
Where can I purchase the NTMA roughness standards?
Don Cohenmetrology - Livonia, Michigan
March 15, 2010
publicly reply to Don Cohen
Hi, Don. It appears that you can buy this direct from www.ntma.org. I currently see it listed under store>publications>mold finish specimens kit.
March 16, 2010
publicly reply to Ted Mooney
