Which type of Additives / Chemicals / Surfactants can be used for rinse aid in cathodic electrodeposition?
I am going to research on the rinse aid chemicals for electrodeposition.
So I am interested in this subject.
Milap Padh
researcher - Jamnagar, Gujarat, India
I would suggest that you look up a chemical formulary as well as the technical information available from surfactant manufacturers.
Gene Packman
Are you seeking to hire someone to do your research?
Ken Vlach [deceased]
- Goleta, California
