Are Sparks Normal in Alkaline Anodizing of Titanium?
Hi;
I am trying to make anti-wear coating on titanium's surface by anodizing it in highly alkaline solution.
I have prepared a solution which has got pH > 14. After passing 130V there are sparks occurring at the surface of the titanium. Sparks are very little and forming at all over the surface. when I get to 200V spark amount is increasing and I hear a buzz sound.
are those sparks are normal? for a proper coating what is the suitable voltage.
thank you very much.
student - Karlsruhe, Germany
I have not come across alkaline anodising of titanium.
My thoughts are that making titanium anodic in an alkaline solution would be a very good way of dissolving the titanium to produce (sodium/potassium) titanate.
At 200 volts, I am not surprised to see sparks! I would look very carefully at the safety of this.
I suggest that you use 10-20% sulfuric acid and consider 50 volts absolute maximum
I have tried acidic solutions. I think, they don't provide any wear resistance. they are just colouring the titanium by thickening the surface oxide layer.
Jason Talasci- Karlsruhe, Germany
You are correct, Jason. You may see AMS 2488D as a starting point.
