  Thread 458/11
Which grade of Stainless Steel for Sulfuric Acid Purification System?
I want to use stainless steel pipe for a membrane system to purify sulfuric acid of 8 to 10% concentration. Which grade of Stainless Steel pipe should be suitable for such an application. My system will work at a pressure of 35 kg/cm2. The Sulfuric acid will be pumped into the system with help of a high pressure pump.
Yamesh Dave
Designer - Vadodara, Gujarat, India
publicly reply to Yamesh Dave
What are the impurities and their maximum concentrations? Maximum temperature? Maximum flow rate? Is the solution aerated or ~oxygen-free?
Zirconium may be more suitable than any stainless steel.
Ken Vlach [deceased]
- Goleta, California
publicly reply to Ken Vlach
