Copper plating isn't sticking onto SS foil
My goal is to put a .35" diameter circle of copper, about 0.005" thick, on a 0.0015" thick x 1" wide SS foil strip. (300 series SS feeler gauge from Eastern Industries: www.easterngage.com/stock-feeler-gages.asp)
My purpose is to conduct some heat transfer experiments, including lateral transfer rates.
My experience is science fair electro-plating of Cu on carbon steel, using copper sulphate, and Ni on carbon steel, using nickel ammonium sulphate [affil link to product info on Amazon]. My "prep" consisted of simmering the steel briefly in vinegar in bulk on eBay or Amazon [affil links] . The plating looked really good.
I tried Cu on SS last weekend, got good deposition, but it FELL off. I only cleaned with acetone on one trial, but also used emery cloth to roughen the surface on the other.
I have gathered--from a metal roofing website: home.comcast.net/~easyroofsales/copper_plated.htm--that I might have better luck if I 'prime' the surface with a bit of nickel, then plate copper over that.
My equipment includes a lab-grade power supply, so I can control current density with ease.
I hope someone finds this intriguing!
David W Pennington
hobbyist plater, but professional labrat, otherwise - Fox Lake, Illinois, USA
Indeed, stainless steel must be nickel plated first -- but not just any nickel plating, it needs a Wood's Nickel Strike (high chloride, acidic, low nickel concentration). Info can be found by searching this site or in the Metal Finishing Guidebook.
