What should I build a solar dish out of?
Hi everyone,
I have been spending lot of time around the internet, trying to figure out how to build a cheap, self-made solar dish to produce
(very) hot water.
I have been investigating every possible reflective material, metals included, but still I can't understand what could be good and what would be not.
I thought of aluminum, stainless steel, brass (and many more), and different coating/polishing/anodizing procedures, but I do not know if these will reduce reflectivity.
As I need a long-lasting, resistant and highly reflective material, what do you think is best?
Hobbyist - Bologna, Italy
High purity aluminum, bright dipped and with a minimal thickness of anodizing, should prove very economical as well as very highly reflective.
Thank you very much for the answer.
So, stainless steel is not a good idea at all? Why?
And, could you suggest any technical data on the aluminum solution (i.e., which alloy is better, thickness on anodizing layer, buffing solution).
Thanks again.
- Bologna, Italy
I don't work in the solar field so I can't quote absorbtivity, emissivity, and similar parameters for the various metals without research, Giovanni -- but some materials that appear to be bright and reflective are not good reflector material. For example, to the surprise of most people, chrome is a very good absorber and a poor reflector. Similarly, stainless steel just isn't a good reflector.
For the aluminum, look into reflector design subjects. In general the pure aluminum alloys, 1000 series, are the finest reflectors, but other alloys work well. As a general text, ASM Handbook Vol. 5 covers the subject of finishing aluminum reflectors and mirrors quite well. Good luck.
