Nickel plated surface (on berylium copper) turned greenish
Beryllium copper part, plated with electro-nickel was found with greenish surface.
What would be the root cause of this ?
Supplier - Kulim, Kedah, Malaysia
It sounds to me like the copper is corroding, which is attributable either to inadequate nickel plating for the planned exposure conditions, or the exposure conditions not under control.
