Powder Coating Problem: Structure Formation Sometimes Fails
Q. Dear Sir
We are facing problem with our Powder Coating. We are doing RAL 7032 and sometimes structure formation is not taking place on our components. We have tried to improve our degreasing chemical wettability by adding non-ionic agents and still we are facing the problem. There is no water-break on the components and our Zinc phosphating coating is up to the mark. Please suggest some remedy. So far we've tried two powders from different companies/mfr.'s. Our substrate metal is CRC.
Amitabh Kumar
- Noida, India
? Dear Ambitabh,
You might need to explain this question a little further. What do you mean by "structure formation"?
You mentioned the colour of your powder, but not the type (Polyester, Epoxy, plastic, nylon, other).
Can you describe the symptoms you don't like to see, and then the complete process route you use?
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
Q. Dear Sir
This is a Structure Powder; means a Structure formation takes place after baking of the powder and this is widely used on electrical panels. The formation of structure after the baking is not taking place in some areas, we have tried our best so far but we have come to know that if we use calcium modified phosphating chemical than this problem will not occur because of better conductivity.
If you have any info about this please share with us.
Amitabh Kumar [returning]
- Noida, India
A. Try heating the part before you paint it, the paint will melt to the part and solve some of you coverage issues. This method takes practice because you can overpaint very easily and get runs and drips. It sounds like you might be using dirty hooks resulting in a bad grounding situation, the hooks can't be used more than twice(once is even better) before cleaning.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
Q. Hi
Do you think this is a coverage problem of the powder if so, is there any other solution to this problem as we do not have extra capacity to do all this as suggested by you.
Amitabh
- Noida, India
A. Hi Mr. Amitabh,
It's hard to tell who you are addressing. If you have a bad ground the powder will not stick to large areas of this part, you will get moon shaped areas that have very little powder on them. I think what Mr. Crowley is saying is that "structure formation" is not a term typically used in describing a powder coat condition, so we are basically all just guessing on how to answer your question.
Sheldon Taylor
Sheldon Taylor
A. Dear Amitabh,
I wonder if by "structure formation" you mean the crosslinking of short chain polymers to long chain that happens in curing of powders like polyesters.
It might be helpful if you can describe the symptoms that you see? And what is it that you hope to see that you don't?
geoff_crowley
Geoff Crowley
Crithwood Ltd.
crithwood logo
Q. Dear Mr. Taylor
The problem is that on panel of size 3' x 7' we get small patches around the size of thumb/finger impression where the structure is not getting formed and in that area there is high gloss.
Amitabh
- Noida, India
A. Amitabh, Are you using an oven designed for powder coating? Does it have a lot of air flow? If you have an oven that was built for wet paint, it is essentially a hot box, it will not work very well with the curing of the powder and you could get patches on a large flat surface that will not cross-link and cure. The uncured patches of powder will be shiny.
Sheldon Taylor
Sheldon Taylor
Q. Dear Geoff
We are doing powder on electrical panels and the powder is not a usual plain powder after baking it forms a cross link chain as you say it forms a rough structure unlike plain powder.
The problem is in certain areas that the powder remains plain say in a area of 1 cm2 in two or three places on a panel size of 3' x 7'.
We don't understand why it happens like this; the structure formation should be on the whole panel this is what we want.
- Noida, India
A. It sounds like you are using a textured finish powder.
If that's right, then you should not get this problem you describe. It sounds to me like a powder supply fault - mixed textured and untextured.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
crithwood logo
A. Dear sir,
Have you tried powder coat on panel without phosphating and just cleaning with nc thinner by cloth.
After doing this trial tell us about the results.
Tanuj Tyagi
Tanuj Tyagi
- Faridabad, India
Q. Dear Sir
Yes it is a textured powder but if we are doing cleaning with thinner and doing powder there is no problem but when we are doing degreasing and phosphating then texture formation is not taking place in certain areas.
Amitabh Kumar
- Noida, India
Q. Dear Sir
We have tried all this but to no conclusion as some times the panels are coming 100% OK and some times we have this problem 5-10 %. We have tried many combinations some times we feel it is the powder problem and some times we feel it is Parts Earthing, Gun related problem.
- Noida, India
Ed. note: A picture is worth a thousand words! We already stand at 14 postings and over a thousand words, and we're still struggling because people aren't understanding or agreeing what "structure" means :-)
Please send a photo of the electrical panel with the "structure" and an arrow where "structure has failed to form" to mooney@finishing.com for posting here.
A. Dear Mr. Amitabh,
I under stood your problem that sometimes you are not getting the proper structure pattern which you want. Kindly mention if when you are getting this defect have you checked the DFT over that defective patch and unaffected patch. please inform us.
Dr. Hitesh Hirani
- Rajkot, Gujarat, India
A. I think the problem of patches found in the coating is not due to thickness problems but it could be due to the improper mixing of the structuring additive. This seems to be more of a manufacturing problem and not related to the coating application process.
I would suggest that you try using powder of a different manufacturer and see if you can solve the issue.
Please let me know if the issue still persists.
Thanks and regards,
SANDEEP WADADEKAR
- Pune, India
A. Hi,
My response is that, having already tried a different powder supplier, checked earthing and for oil in the airline you found the problem was still present. We presume that you made sure that an even film weight of powder is being applied 90-100 microns (texture powder requires greater film weight than a standard powder). Therefore, the problem must be something quite simple. Supply your operatives with cotton gloves - your explanation of the size of the defect does point to a handling problem. Let me know if this is possible or not.
Terry
Terry Hickling
Birmingham, United Kingdom
Ed. note: I'm just the curator/moderator but Terry's posting seems right on the mark -- possible fingerprint oils manifesting themselves worst when there's a good phosphatization layer to absorb them :-)
A. You have a SURFACE PROBLEM
PREP
Clean parts, strongly, with acetone this on eBay or Amazon [affil links] Warning! highly Flammable! or alcohol and don't touch them anymore. Then coat.
IMPURITIES FREE
Check for weld, braze, masking removals.
That's it!
Jose Castellanos
- Minneapolis, Minnesota, USA
A. Try the following steps to get better structure results:
a] Maintain a good coating thickness i.e., 80 to 100 microns
b] The recovered powder should be mixed with at least 70% fresh powder. This is also important to maintain shade stability. [Since RAL 7032 is a comparatively lighter shade]
c] After taking these two precautions, you may go ahead and find different suppliers for your powders until you get the desired result.
Manoj Rangraj Jain
- Navi Mumbai, Maharastra, India
A. Hello Mr. Amitabhkumar,
Is your problem solved? If not, please try a simple procedure:
1. Take two ms panels and one Tin panel
2. Clean one of ms and one tin panel with kerosene or N.C.thinner; see that water film does not break to ensure 100% degreasing; dry.
3. Take second MS panel -- Clean and degrease, Rinse, De-rust, rinse, Activate, Zinc phosphate (Zinc phosphate - low coating weight compact silky grain pattern), rinse, passivate and dry thoroughly. Check degreasing is 100% and the phosphate coating is not powdery or coarse. If you do not have Zinc phosphate, wipe the ms panels with three-in-one solution and wipe dry.
4. Now powder coat evenly above 80 microns with three to four cross coats only degreased MS and tin panels and phosphated ms panel with the problematic structure (texture) powder, and bake it with already heated oven to complete cure at 200 °C 10 -15 minutes.
5. Repeat the process similarly with a standard suppliers powder, and compare the results.
Please inform me your results, if there is problem with the powder it will be shown on the only degreased ms and tin panels; if ok, then powder is fine; if problem seen on degreased phosphated ms panels, conclusion is that something is wrong with phosphating parameters, chemical contamination.
Kiron Deodhar
- Pune, Maharashtra, India
December 3, 2009
Q. Dear Amitabh,
We have exactly the same issue coming in our shop.
We have patches appearing on structure(texture) finish panels after curing. we are using structure powder (Siemens Grey, RAL IS 631/7032 powder). Patch appears like oil mark where structure has not opened and it is smooth on patch. Powder is coated with proper thickness (70 to 100 microns).
Coating Guns are Nordson make Vantage manual Guns.
Re-coating and curing would make patch disappear from the panel.
We tried following
- We have re-made the degreasing bath (we use hot degreasing) thinking patches are because of oil residues but it is not helping
- zinc phosphating is happening properly and nail test is showing good phosphate coating
- chemical concentrations in Degreasing and phosphating are as recommended by manufacturer
- pH values of water is also in range
- If we clean the panel with 3-in-1 solution then this is not happening
Not having any clue as to what is causing the problem. Any pointers towards solution would be very helpful.
Kindly share if you had already overcome this issue
c.vishwa
c viishwaraju
powder coating - Bangalore, India
Q. We are using an automated powder coating plant. Our requirement is of min. 50 DFT and max. 65 DFT. But we are getting more than 90 DFT, thus making a loss of powder and profit.
Also, we are not getting a uniform DFT over a area.
Please comment.
Sanjay Mestry
panels, fittings - Mumbai, Maharashtra, India
September 17, 2008
Ed. note: Are you doing 'structured' or 'textured' powder coating, Sanjay? If not, we have dozens of detailed discussions on your topic. Please search the site for "powder coating too thick".
Q. I am facing compacting problem in powder coating from my customers, what factors are involved and how should I investigate and avoid it.
Rashid Mahmood
powder coatings - Dammam Saudi Arabia
July 25, 2012
A. Hi Rashid. Your problem is clear to you, but not to me and maybe other readers. Are you a powder supplier, supplying powders to powder coating shops and the powder clumps up unmanageably?
Some details of the problem would surely help. And again we ask if you are referring to 'structured' and 'textured' finishes. Thanks.
July 26, 2012
Q. Causes of structure formation problems in powder coating and its effects on industries? I am an engineering student and it is important for my future and my interested area.
Reason for producing "structure formation" problem in powder coating.
Patel Niral
student - Valsad, Gujarat, India
August 21, 2012
Ed. note: We have determined from previous entires on this thread, plus further reading, that what the Indian writers are describing as "structured", is faitly close to what British & American readers would describe as "textured" or "wrinkled".
September 12, 2012
A. The question is a little vague.
I assume there is a significant difference in appearance of various areas of textured or wrinkle finish (structured) powder coating?
The most obvious cause would be that a vibratory feeder rather than an aeration feeder system is in use.
Special effect powders require constant re-mixing thus aeration feeder is mandatory.
Hope this helps.
Bill
William Doherty
Trainer - Salamander Bay, Australia
A. Okay I'll guess at this too! I will assume your discussing textures, etc. First let's agree that you need to have proper pretreatment because if the substrate still has debris on it or it has oils on it, the texture will probably be compromised and/or fail to be cosmetically acceptable as well as fail in performance.
Next, you need to have a viable powder to use. It needs to be powder that is not out of date because out of date powders tend to have many issues, especially textures.
Make sure the texture is being readily refilled with virgin powder at a rate that will continue the cosmetics and performance you require. Make sure your powder supplier tells you if they make ANY changes to the powder or its manufacture. Like any company, they do this because they regularly change their supplies and even though they may say the change won't change your product, I have found they may. Make sure that the substrate is subjected to the proper stoving every time. It's just important to make sure you control the entire process so you don't run into issues. That way, if something does go wrong, it will be easier for you to troubleshoot it.
bob utech
Bob Utech
Benson, Minnesota
powdercoat_utech2002
Ed. note: Bob is the author of:
"High Performance powder Coating"
on eBay or AbeBooks
November 8, 2012
DFT issue in structure finish
Q. Sir we are facing problem to maintaining uniform DFT on powder coated components. Powder pattern is structure. DFT is observed 55 to 150. How to maintain it uniformly. Please help.
Kuldeep Kumar
Powder coating - Mohali Punjab Indian
October 10, 2018
QUICKSTART:
(to help readers better understand the Q&A's)
DFT is dry film thickness.
"Structured" appears to be a term used in India similar to "textured" or "wrinkled" in the USA.
A. Hi Kuldeep.
I think we need more words. One piece is 55 microns and the next is 150 microns, or (more likely) the coating thickness varies over a single part? Does it vary on edges compared to the middle of flat expanses, or is it lower in concave recesses, or are there blobs of thick powder in random locations? How is the powder applied, robotically or by various operators? There are no other problems -- no pinholes, discoloration, orange peel? You probably need to tell us exactly what you have found in your investigation if you want help in taking the investigation further. Good luck.
October 2018
Q. Dear Sir
This variation is coming in same piece. Our coating procedure is manual. As the powder finish is structured or texture finish, the Dry film thickness is not uniform as compared to plain finish. We have also calibrated DFT gauge. How can we maintain uniform DFT on the component, i.e, 80 to 100 microns?
Kuldeep Kumar [returning]
October 11, 2018
Q. How to make masterbatch for getting bold structure finish in powder manufacturing process using epoxy Resin?
Rajagopalan Ranganathan
- Tambaram Sanatorium, Chennai, Tamil Nadu, India
October 24, 2020
A. Hi Rajagopalan. All questions are welcome, but not all questions are likely to get replies :-(
We'll see what happens though :-)
October 2020
