Finish for aluminum busbar in contact with silver plated copper busbar
I am looking for appropriate finish for an aluminum busbar bolted to a silver plated copper busbar.
Application is 500 Amps, computer room environment.
Should I use a class 3 MIL-C-5541E chromate or MIL-T-10727C type I tin plate?
Should my silver plated copper busbar be tin plated?
Thanks in advance.
Engineer - Canton, Massachusetts
At the least, the contact areas of aluminum bus must be electroplated; chromating will not do. Because the copper is already silver plated, I think you should have the aluminum silver plated.
