Abrasive Blast Cleaning Titanium
can I safely abrasive blast (glass bead)titanium parts for weld prep
Joel Mohnacky
product design - Machesney Park
"Abrasive Blasting Operations"
by NIOSH
abrasive_blasting
AbeBooks
That should not be a problem as long as you do not blast any other alloy in the cabinet.
Yes, but do it as a wet blast.
Brian Terry
That's a leading question. It's like having an hand accident and asking the doctor can I play the piano again and not ever having played it before. So, the answer is yes if you have done it before. If you use alum oxide media, that might be a problem.
tony kenton
AF Kenton
