Corrosion of steel reactor from dilute sulfuric acid
I AM USING DILUTE sulfurIC ACID OF 60% PLUS 39% WATER AND 1-2% NITRIC IN MS REACTORS AS WELL AS SS REACTORS.
GUIDE ME WEATHER THERE WILL BE ANY CORROSION TO REACTORS?
MANAGER PLANT - INDIA
Your mild steel reactors will disappear very quickly indeed in a pool of ferrous/ferric sulphate!
Bill Reynolds [deceased]
This acid solution in mild steel sounds like a recipe for disaster. Coat the mild steel with an impermeable plastic, perhaps a vinylester resin. Are these weight or volume % concentrations? What temperature range will this operate at?
There are too many grades of SS and your conditions are inadequately defined to comment.
See letter 44789 for some links on sulfuric acid-compatible materials. The Resistoflex site information on sulfuric acid may be useful, such as temperature rise for various dilutions of concentrated sulfuric acid.
- Goleta, California
As Ken Vlach said, you have a recipe for disaster... I wouldn't be so optimistic !
The nitric will add to you problem.
Then you have to consider the emission problems. Wowee, I'm sure glad I ain't in your shoes.
But I am not a lover of add-ons ... but would think of a dual laminate approach ... in fact I made the first ones in Canada or the USA but now I'm retired, I can say that.
Then, of course, you have to consider the affects of your brew on the welds. Ah! Luver-ly. Yum, yum, yum.
Freeman Newton [deceased]
