Corona or/and plasma surface treatment
We clean the polycarbonate sheets by solvent for bond it to the aluminum by using adhesives. Sometimes we get delamination. The reason could be non-surface treated of the polycarbonate.
In order to over come that, I have been thinking of using the corona or plasma treatment.
Please could anyone give me the positive and negative points of using this method.
Engineer - UK
Salar
The problem with bonding to polymers is twofold.
1/ The correct adhesive
2/ Cleaning the surface. The usual surface contaminant on polymers is either low molecular weight polymer on the surface or non-stick agents applied to prevent the polymer bonding to the mould. The easiest and cheapest way to clean the surface is a detergent wash followed by thorough rinsing. The problem with solvents is that they can evaporate and re-deposit whatever grease they have dissolved.
Plasma/ corona are very good and VERY expensive. I would try the simple solution first.
But I would also take advice from the adhesive supplier.
