Plating on Lead bronze Alloy - LB2
We are one of the electroplaters in Bangalore we need to know the pickling Procedure for Plating on LB2 Alloy.
The composition of the base is as follows ;
BS
LB1
LB2
Element
Min %
Max %
Min %
Max %
Copper
Rem
Rem
Tin
8.00
10.00
9.20
11.00
Zinc
1.00
1.00
Lead
13.50
16.50
9.00
10.50
Phosphorous
0.10
0.05
Nickel
2.00
2.00
Iron
0.15
Aluminium
0.01
Manganese
0.20
Antimony
0.50
0.50
Silicon
0.02
sulfur Niobium
0.10
0.10
Impurities
0.30
0.50
Any information on this we would be of high interest to us.
Shreesha Acharya P
Manager - Bangalore, Karnataka, India
That amount of lead will absolutely require the use of a fluoboric (not HF) for the etch step.
Jim is right, you need a fluoboric acid dip
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
