Smoothing surface of stainless steel casting for food grade application
Is there a metal finishing media (shot blast) that will smooth out the A3 finish surface of stainless steel casting for food grade application?
John Campbell
OEM Machine manufacturer - Kalamazoo, Michigan, USA
Define smooth.
Normally you can not achieve a good surface finish for FDA applications using a blasting process.
tony kenton
AF Kenton
