Testing Hardcoat with a Conductivity Tester
I have a tool (6061 Al)that was welded (2139, machined, and then anodized (hard coat). The appearance looks like an alligator skin with a montage of green and silver marks. Can you test with a conductivity tester to see if the hardcoat is present?
Mike RuleEngineer - St Louis, Missouri, USA
Hardcoat conductivity can be tested by ohmmeter with two metal contacts. Set the scale limit to 1 k-ohm, slightly touch the surface with two contacts in the distance 1-2 sm from each other. If ohmmeter reading shows more than 1 k-ohm, that it is good anodizing. However thickness of the coating can be tested only in metallographic laboratory with special equipment.
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
