Using temperature to free glass from stainless steel
I currently a junior in high school and have a piece of glass that I draped over a stainless steel cylinder. The problem is the cylinder was not a perfect cylinder and I now can't get the glass off it. Do you have any suggestions of either cooling the cylinder since metal should contract faster than glass or corroding the cylinder(which is already rusty)?
David C. [last name deleted for privacy by Editor]
student - Studio City, California, USA
Try WD-40 this on eBay or Amazon [affil links] , David, then try putting it in a freezer. Don't believe what you see about acid in movies; it will prove totally impractical to dissolve the cylinder.
