What are the standard limits of baths in hot dip galvanized process?
Q. I'm chemical engineer in ministry of trade and industry and I want to know, What are the standard limits of baths in hot dip galvanized?
Eng_Ahmed Saied
chemical engineer in ministry of trade and industry - Cairo, Egypt
simultaneous replies 2007
A. Sir:
What do you mean by "BATHS?" Do you mean caustic, caustic rinse, acids (which one), acid rinses (how many), flux solution, zinc bath, quench, passivation tank? Are you trying to "standardize," or improve the results for government owned galvanizers? What types of products are you asking about. Sheet, wire, bolts, structural, pipes are some of the possibilities.
Dr. Thomas H. Cook
A. Your question isn't specific enough.
What do you mean by standard limits?
Size limits?
Temperature limits for the molten zinc?
Limits of heat transfer through the kettle wall?
Width to depth ratio limits?
Throughput limits? (as in tonnes per hour?)
Impurity limits (as in say Sn, Fe, etc in the molten zinc)
Additive limits (Pb, Ni, Al etc )
freeboard limits (how much kettle wall should be exposed above the top of the zinc?)
So what actually do you need to know?
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
