How do we dissolve the copper coating on steel wire
I am producing copper coated steel wire. I want to determine the weight of copper coating on the surface of steel wire. Can somebody suggest a solution which dissolves only copper leaving the steel wire intact?
Rakesh Bansal
Manufacturer - Parwanoo, Himachal Pradesh, India
Rakesh,
Wouldn't it be easier to weigh the wire before and after plating to get your copper weight? You could also measure the copper plating thickness on a given amount of wire and calculate from there (grams/sq").
If you have to strip the copper from steel 500g/l chromic acid and 50g/l sulfuric acid at room temp should be sufficient.
Mark Baker
Process Engineer - Syracuse, New York
