Mixing stainless steel parts in anodize process?
Q. I have an assembly consisting of two aluminum pieces that are held together with a stainless steel pin. Originally, I planned on getting the aluminum pieces anodized and then drilling them and pinning them in the assembly process. It would be simpler to drill and pin before the parts are anodized.
If I pinned the parts together before processing, and then the entire assembly is anodized (including the stainless steel pin), will it cause any problems? If the stainless steel pin goes thru the tanks, will there be any negative effects (bad adhesion, chemical mixing, etc)?
Thanks very much for any assistance you folks may be able to give.
Bill Donakowski
consumer, engineer - Berkeley, California, USA
simultaneous replies 2007
"The Surface
Treatment &
Finishing of
Aluminium and
Its Alloys"
by Wernick, Pinner
& Sheasby
pinner
(note: this book is two volumes)
AbeBooks
probertEthumb
Aluminum How-To
by Robert Probert
Also available in Spanish
You'll love this book. Finishing.com has sold almost a thousand copies without a single return request :-)
A. The stainless will vanish. Poof!
A. If the stainless pin is not completely isolated from the anodizing bath, it will burn up (dissolve) during processing. If I were you, I'd assemble after anodizing. You can pre-drill your pin hole(s), and have your coater mask it during processing.
Marc Green
Marc Green
anodizer - Boise, Idaho
A. The stainless steel would be destroyed during the anodizing process and take a fair chunck of the aluminum with it.
Get them anodized separately, then install the steel.
Jim Gorsich
Compton, California, USA
A. The stainless steel, since it does not coat and hence insulate, will draw all the current until it completely dissolves and falls out !
robert probert
probertbanner
A. See MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA] ANODIC COATINGS FOR ALUMINUM AND ALUMINUM ALLOYS, Para. 3.3.1.2. It's not a good idea to anodize assemblies. The electrolyte wicks into joints, is very difficult to rinse and causes corrosion. Chromic acid anodizing is an option where assemblies must be anodized, as residual chromic acid rather inhibits corrosion.
Dissimilar metals, if exposed, are typically destroyed during anodizing. As anodic oxide forms on the aluminum, current preferentially flows through the non-anodizing metal which electrochemically dissolves ('burns'). Stainless also gets hot due to ohmic heating (SS conductivity 2-3% IACS vs. 40% for Al 6061), which accelerates the electrochemically attack.
It may be possible to mask off the SS, but also make sure that it doesn't carry significant current between the aluminum pieces. A titanium pin might work, as titanium also anodizes, but it also has low electrical conductivity. Why not design an aluminum alloy pin to avoid galvanic corrosion issues?
Ken Vlach [deceased]
- Goleta, California
A. Try with paint of nails, if you cover well there's no problem.
Oscar Gtz
- Jalisco, Mexico
Anodizing aluminium with steel pin
Q. I want to anodize an aluminium brake caliper for an oldtimer. The problem is that the caliper has a pressed in steel pin for guiding the brake piston. And it's not removable. What is the best method of masking/insulating this pin? What can survive in the acid?
Laszlo Rogacs
restorer - Hungary
August 28, 2018
A. Hi Laszlo. A liquid maskant, probably applied in more than one layer, probably offers the best chance of survival, especially if you start at the hole the pin goes through and make sure there can be no wicking into it.
August 2018
Q. Good Day,
I have some automotive clamps, the main body is aluminum and the clasps are stainless steel. The aluminum is purple , I know I can strip the purple anodizing , Can I get the clamps anodized in black without affecting the stainless in strength or color?
Jay Stump
Spring Valley Motors - Owings Mills, Maryland USA
April 3, 2020
A. Hi Jay. We attached your inquiry to a thread on the subject which makes the point that while it may not be strictly impossible, it's probably impractical; the masking would have to be perfect and failsafe.
April 2020
A. To be clear, if you try to anodize aluminum which is connected to stainless steel, the aluminum will immediately insulate and then the current will go to the stainless steel and start dissolving away. As Mr Mooney implied, the stainless steel will have to be 100% masked.
robert probert
probertbanner
April 6, 2020
A. Bob is spot on with his comment. Just give it up if you can not remove the stainless from the parts
drew nosti
Drew Nosti, CEF
Anodize USA
Ladson, South Carolina
anodizeusa1
April 7, 2020
finishing.com is possible thanks to our supporting advertisers, including:
maskcoat banner
