Machining before chromate conversion coating
A customer wants a Chemical Conversion Coating, Coat Per AMSC5541, Class 3. This is to be applied on 6061 T6. What machined surface finish should this part be machined to?
Jeff Curley
Machining - Delia, KS, USA
I does not matter; however, note that work hardened area will have a slightly different color.
robert probert
probertbanner
