How to fix a worn out Kanigen plating?
I have a Kanigen ball with a flow hole in the center. Its plating is not uniform as result of its rough surface. How to fix it? We do not want to 1. apply Epoxy coating, 2. repaint Kanigen solution, or 3. weld.
Is there any other CHEAP way?
Hua Ning
Engineer - Houston, Texas
Expensive or not, I think the surface must be properly prepared and replated, Hua.
