Electro chrome plating on meat grinder
Q. Greetings,
recently purchased a grinder with electro chrome plating. I wonder if it is safety. I know a little about Cr+6.
is it more harmful for the worker working with acid and environment than a final users?
consumer - St Louis
A. The chrome plating on the grinder will not harm you. As for the rest of your question ... ?
Frank DeGuire- St. Louis, Missouri, USA
A. Only chromium compounds are toxic (especially hex chromates), chromium metal is safe. Hope it helps and good luck!
