My assignment
Well I'm doing an assignment on acids and stuff so I wish to find out acids used in households. Not about all the pH and that mumbo jumbo which I already learned. By the time someone reads this probably my assignment would already be due so I just may as well say I like Elements.
P.S.: My favorite are Au, and (I'm adding two which are not really elements) St, Ai, Li, and to finish A (not a element either). If you get the unfunny joke that is where I'm from lol. Cheers if you laughed.
Ta.....
QUINN M
student - solve the puzzle
wikipedia
Periodic Table 44506
So you say you are from atomic numbers 79+16+[65-5]+[44-92]+13+53+[89-6], then Quinn?
Vinegar is the most common household acid, and it is dilute acetic acid this on eBay or Amazon [affil links] . battery acid this on eBay or Amazon [affil links] , which is not quite household, is sulfuric acid. Some metal polishes are largely sulfamic acid. Lemons have citric acid . Good luck.
