Acid Zinc Plating is Failing Required Salt Spray Test Hours: gets black spots
Q. We had some components plated with zinc electroplating conforming to ASTM B633, SC3. After 96-hours of salt fog testing, we do not see evidence of zinc or base metal corrosion, but we see small black dots. Does anyone have any idea what these black dots represent?
Marc Pepi
US Army Res. Lab. - APG, Maryland, USA
A. Marc,
The black spots you are seeing are the first stage of corrosion of the zinc film.
Without knowing the exact chemical composition of the "black spot", almost certainly these will develop into white corrosion areas of zinc oxide complexes. The time taken to change to white "rust" is not predictable and although the spots may be unsightly, they are not truly a true corrosion break-down.
Hope this helps explain.
Patrick McILVENA
Melbourne, Victoria, Australia
Q. Gentlemen,
I have gone through all the letters regarding Salt spray testing of zinc plated parts.
I have run into a problem with salt spray testing results.
I am making ABS Exciter rings. Originally the material specified is SAE 1026 but we are making these parts in Ductile-iron 420/15.
After Salt Spray Test for 96 Hrs, the parts show some black Spots & white substance on the surface.
The part must stand for 96 hrs of testing. Reference for the plating is ASTM B242 and A164 1
The part is chromated after plating. Yellow finish is required. Plating thickness is 0.0002"
Could anyone help me out of this situation. Frankly speaking I am fairly new in this field.
Arshed Saddique Lakhesar
Machined parts Vendor to OEM - Rawalpindi, Pakistan
Ed. note: 1. ASTM A164 was withdrawn in 1981 and replaced by ASTM B633
A. Dear Arshed,
There are suppliers of process chemicals which can give you up to 350 Hrs White Rust over Zinc and zinc alloy plated components. This forum has been dealing with such topic in details. Kindly refer thru again.
t k mohan
T.K. Mohan
Parts are ductile iron
Q. Dear Mohan.
Thanks a lot for the response. My Problem is Zinc plating a Cast Iron family metal which is Called S.G. Iron or Ductile Iron or yet again called Nodular Cast Iron.
After 48 hours of salt spray small black spots are seen but no loss of yellow colour. But after 96 hours loss of passivation is observed.
How to avoid the black spots on the surface is my problem. I have done a lot of search through these letters to get a little clue.
HELP, HELP
Arshed Saddique Lakhesar [returning]
A. Dear Arshed,
Plating on castings is one of the most difficult and widely discussed in this forum. I will give you some tips where you can get an immediate remedy --
1. Take utmost care in cleaning. Your cleaning sequence seems to be inadequate.
2. Introduce air agitated hot water rinse with extra time before going to the plating tank and after plating. This will clean up pores.
3. Acid chloride zinc plating is widely used for plating on castings.
4. If you want enhanced Red Rust go for cobalt alloy.
5. Hex-free (trivalent passivation) gives better White rust life.
Arshed, please give out more details such as what chemistry you use and what is the process sequence.
I can help you if you are more clear.
t k mohan
T.K. Mohan
Q. Dear Mohan,
By the look of it, it seems to me, that microporosity in the metal is causing the black-spots on the surface. Zinc plating is not covering those tiny holes which are not visible to naked eye.
Originally the metal was steel but we changed it to ductile iron as it is easier to machine than the steels.
As requested I will let you have the process flow I am following to do the job.
Regards & wish you all the best.
thumbs up signThanks arshed,
All the best for you.
Regards.
t k mohan
T.K. Mohan
A. Dear Arshed,
White corrosion is due to inefficient chromate (passivation in your words), and red corrosion is due to lack of thickness of zinc layer (0.0002 does not look like it's good enough).
Check and see how many hours of corrosion protection your chemical supplier claims on the yellow chromate.
Development of black spots means failure of chromate passivation and eventually you will see white rust falling off and then it will be all red later on.
You may need to work on the pH, time, contamination on the yellow chromates and all the rinses before and after the yellow chromate. Also pay attention to quick drying of these parts.
Hope it helps
Hemant, USA
Hemant Kumar
Hemant Kumar
- Florida, USA
thumbs up signDear Hemant Kumar
Thank you for the tips. I eventually managed to get through 48 hrs instead of 96 Hrs salt spray test. The OEM gave deviation on it. Quick drying worked as well! Rubbing of parts with each other during and after chromating process helped a lot as well.
Once again thanks to all the well wishers.
A. Dear Arshad,
Thickness of deposit is 5 microns. I believe that it should be minimum 8 microns. Also use a better quality passivation. Yellow Trivalent passivations provide more than 200 hours of salt spray test.
Basharat Javaid Awan
- Lahore, Pakistan
A. Hi. Arshed has received some good advice here, and apparently benefited from it ... but what should not be lost in this discussion is that the presence of black spots in salt spray testing is NOT failure. If black spots appeared at 48 hours, but white rust did not occur until beyond 96 hours, he passed a 96-hour salt pray test :-)
Black spots within 6 hours
Q. We are using zinc electroplating with trivalent bonding, colour: white, but we are getting black spots within 6 hrs and white rust within 24 hrs, how to avoid this? We want white rust to be prevented by 48 hrs and red rust by 132 hrs. Please suggest appropriate solution.
Raman Raj
- Hyderabad,AP India
September 27, 2008
Q. Recently we tested trivalent Zn plated some parts as per ASTM B117 in India at my supplier, and it gave us a white rust life of 240 hours. However, when we sent it to our customer in Germany, they reported white rust within 24 hrs .
Both parties claim to have done all the testing as per ASTM B117. Now, I am stumped. Can you tell me where to start looking?
Manish
Manish Talwalkar
- Pune, Maharashtra, India
A. Manish,
You have to look into packing. As the product is usually shipped through sea and takes months to reach the buyer, due to corrosive sea atmosphere, it is possible the plated items get effected. Best way is to adopt VCI (Volatile corrosion inhibitor) packing. Packing should not be done until 36 hrs after plating.
Good luck
t k mohan
T.K. Mohan
July 16, 2010
Q. DEAR SIR,
CAST IRON AUTOMOBILE COMPONENTS, CHLORIDE TYPE ACID ZINC PLATED 8-12 MICRONS, TRIVALENT CLEAR PASSIVATED FOLLOWED BY LACQUERING. DURING SALT SPRAY TEST DEVELOPS LIGHT YELLOW COLOUR AFTER 480-500 HOURS, BEFORE RED RUST. IS THIS ACCEPTED AS PER INTERNATIONAL NORMS?
PLEASE LET ME HAVE YOUR ADVICE.
THANKS & REGARDS
RAJAGOPALAN RAMANATHAN
- CHENNAI,Tamil Nadu, India
January 29, 2010
A. Rajagopal,
Yellowing before red Rust can happen.
Since you are plating on cast iron which have pores. Please see that your plating bath is treated weekly to remove iron contamination in the bath.
t k mohan
T.K. Mohan
July 16, 2010
Q. I am having the same situation but the base material is sheet metal. Does sheet metal have pores too.
Goh YL
- Georgetown, Malaysia
December 10, 2010
A. Hi Goh. Sheet metal would generally not have such pores, but pores are but one of many causes of black spots. Further, there are many different types of black spots -- so believing that you have 'the same situation' as Rajagopalan when neither of you has introduced photos could be misleading. Please send us a couple of photos of your black spots if you can, and tell us your process sequence. Thanks!
! Rule of thumb, when plating Trivalent Zinc and if you want 96 Hours SST to pass, you will need a minimum of 8 µm or .0003" plating thickness to achieve such. If this isn't the concrete requirement, I'd recommend an organic finish (more money, but worth the price to the environment).
I am a Quality Manager for a fastener distributor and we get these parts plated on a routine basis.
Now if you are plating a fine threaded part - you'll have issues in gaging parts on a calibrated gage - however, parts will thread onto a mating end or nut with no issues, but the industry does not recognize the second method as a Pass or Fail - conformance shall be done with a calibrated tool.
So you engineers out there who require certain plating thickness for a fine threaded part, you're going to have conformance issues with your QA Department, because there isn't enough room for the plating and the gage's threads to gage.
Bob W [surname deleted for privacy by Editor]
- alsip, Illinois
May 20, 2011
Ed. note: Thanks Bob!
Q. Why black spot or patches formation during Salt Spray Test of Zinc Plated items?
ARIJIT DAS
- Jamshedpur, Jharkhand
March 8, 2012
Q. Anyone help me to get what is the minimum hrs requirement in ASTM B117 for automobile components in sheet metal after heat treatment.
Krishnan Arumugam
- Chennai, Tamil Nadu, India
July 5, 2012
A. Hi Krishnan.
I don't think anyone but the automobile manufacturer can tell you that, but I think 120 hours would be a good number if you have no spec to meet. Some zinc plated sheet metal parts get painted, and those will deliver much higher salt spray ratings.
But remember that the point is not to design to a specific number of hours, since that number is meaningless in terms of real world performance. The point is to design a robust plating cycle, see how many hours it withstands when well controlled, and use the salt spray test to assure that it stays controlled to that level.
July 5, 2012
Q. Dear All
I am not able to sustain SST life more then 12 hours in white passivation during plating on fasteners.
We are having Acid Zinc bath & Trivalent white passivation.
I've already rechecked all the process parameters & re-examined all the process bath concentrations. What steps should I follow to closely examine the process again to sustain SST life of the product.
Vinkush Sharma
- India
May 4, 2013
A. Hi Vinkush. If you have a reasonably operated zinc plating line and are getting only 12 hours to white rust, it certainly sounds like your trivalent passivation is not working correctly.
This is a modern replacement for hexavalent chromate from a reputable vendor, not an old fashioned trivalent of the 1960's (which were, in fact, designed for 12 hour salt spray life)?
April 2016
Q. Black spots are observed on the surface of acid zinc barrel plated components treated even if high end /thick film trivalent or hexvalent passivation with top coat /sealant. In acid zinc iron impurities are very low & brightener level is also moderate.
Black spots are observed in salt spray within 16-48 hours of salt spray, and customer rejects the material saying salt spray fails.
What could be the reasons? Acid zinc solution is filtered and kept is good condition.
Shailendra Badve
- Vadodara, Gujarat , India
June 3, 2013
A. Hi Shailendra. As you see, we appended your inquiry to an extended discussion on the topic. If there is something different about your installation that the readers should be aware of, including what type of parts and what kind of steel you are plating onto, please let us know. But black spots probably do not constitute salt spray test failure unless the customer has written it into their own specs, as I don't think you'll find that guideline in any recognized spec. Thanks.
June 4, 2013
