Non-Cyanide Zincate for Aluminum
I am a continuous plater, and I am starting to get requests for continuous tin plating of aluminum strip stock. It looks like I will need to look into the use of a Zincate for the aluminum as a pre treat before tin plating. Most of the advice on the web involves the use of cyanide based zincates. A couple of my vendors do provide non-cyanide zincates, and that looks like what I will use. Has anybody done continuous aluminum electroplating before, and if so, please include a general process that was used. It is very important that I avoid the use of cyanide in this case, as I have yet to use it for any application in my shop, and do not look forward to doing so. Thank You in advance for all suggestions.
Michael Berrier
- Addison, Illinois, USA
Since they want tin on top,it would be a better galvanic couple to just use the proprietary stannate to start the plating.
robert probert
probertbanner
