Palladium plus rhodium plating procedure for yellow gold rings
Ed. note; This is an interesting thread, and only one of many. Before you get too confused, you might want to start with our FAQ on Rhodium Plating and White Gold to get an overall understanding :-)
! I have noted many questions on this forum regarding flaking of rhodium or other poor color results in the rhodium plating of yellow gold rings. I have personally experienced all these problems, and after much experimentation, have come up with the following procedure. I have plated six yellow gold ring sets with rhodium over palladium, with incredibly beautiful results. The process I have settled on is:
1. Buff ring to brilliant shine with brown tripoli buffing compound this on eBay or Amazon [affil links] , then Fabulustre [affil links].
2. Soak in 1:1 hot isopropanol:linseed oil liquid soap. Use toothbrush to clean diamonds and mounting.
3. Plate with palladium, 1 minute, 6 volts, room temperature.
4. Buff to shine with rouge cloth.
5. Repeat steps 2 - 4.
6. Soak in 1:1 hot isopropanol:linseed oil liquid soap.
7. Plate with rhodium, to a definite bluish tint compared to palladium color, about 40 seconds, 2.3 volts, room temperature.
8. Buff to shine with rouge cloth.
Two things I've learned:
1. The palladium is not only a very beautiful barrier between the yellow gold and the rhodium, but is probably the easiest thing I've ever plated. The adhesion to and color masking of the substrate are fabulous.
2. Rhodium goes over palladium better than over 14K gold, and as good as over a 24K gold underplate. Although it takes a bit longer, plate rhodium at 2.3 volts instead of 4 - 14 volts. This avoids the stress flaking you get after awhile at the higher voltages, and the adhesion is far superior. I played around a bit to find this out.
There is a difference in color between the silvery-white palladium and the more bluish-tint rhodium. However unless you really look hard, when the rhodium wears off you cannot see the difference with the palladium showing through -- a far better situation than yellow gold showing through.
The palladium and rhodium solutions I used were supplied from LDC Company, W.R. Associates, Inc.
Robert L. Nelson, Maryland
The Silver Doctor - Indianapolis, Indiana, USA
thumbs up signThanks for the great exposition, Doc -- and nickel-free to boot! My only reticence about it is that, while this is a perfect prescription for consumers who are already stuck with rings of the wrong color for their taste, I hope it's not so good an answer that jewelers expand upon the recently observed practice of plating yellow gold to make it look white. If someone buys a white gold ring, it should not merely be palladium-rhodium plated, it should be white gold alloy under that plating.
Q. What would cause rhodium to come off a ring in flakes, I have been plating for 20 years and have had this problem before
Al Bradice
Jeweler - Stuart, Florida, USA
January 28, 2013
A. Good day Al.
In my experience with jewellery, I know the rhodium deposit is extremely thin, as 0.000005". I think the "flakes" you are seeing is the underlying nickel (or other metal used to seal the substrate,and give the ring a bright ,reflective and hard coating to accept/produce a bright , lustrous rhodium deposit.)
What is the colour of the underside of the "flakes"?
What is the colour of the ring when the "flakes" are removed? Are you seeing base metal?
I would suspect the base metal was not properly cleaned / activated for the underlying metal deposit before rhodium plating, giving poor adhesion on the base metal.
Hope this helps.
Eric Bogner
- Toronto, Ontario, Canada
February 1, 2013
A. Good day Al.
I might have given you the wrong info, as you are a seasoned veteran regarding rhodium plating for 20 years.
I have in fact seen the rhodium only flake. There were multiple instances.
A) Badly passivated nickel prior to rhodium. These items were processed in D.I. water and left idle too long prior to rhodium plate. I do not recommend D.I. as it causes accelerated rates of passivation.
B)Combination inadequate nickel preparation prior to rhodium, excess nickel brighteners (I always used cathodic alkaline electroclean after nickel plate for this reason) as overload and ORGANIC contamination. The electrocleaner will address this, providing the electrocleaner is not overly loaded with metallics/organics, as they will be deposited on the nickel substrate.As you well know, sulfuric dip after electroclean is vital to be "pristine" as is the rhodium solution itself.
Metallics generally cause dull, dark deposits, whereas organics cause adhesion issues.If the flaking is not intermittent, I would carbon treat the solution @ elevated temperatures, paying close attention to carbon adsorbtion/contact time, as you know, carbon will reduce rhodium metal concentration
Hope I was a little more specific.
Eric Bogner
- Toronto, Ontario, Canada.
A. Hello Al,
Because you are an experienced plater I would assume your pre clean process is in order. This is the first area I would look at however. Is this pen plate or a tank process? If it is tank plating, has there been a recent chemical analysis? Next I would make sure you are getting the proper amperage on the anode and cathode bars by a clamp meter check, also check your connections and anodes. Unfortunately there is not one single cause for peeling of plating but a process of elimination is required. Hope this helps.
Mark Baker
Process Engineer - Mesa, Arizona, USA
February 1, 2013
Q. Is the palladium and then rhodium plating applicable utilizing pen plating?
I like the option of selective plating yellow gold jewelry, and I would like to utilize that two-step process for increased durability.
Peter Ordon
- West Babylon, New York, USA
December 14, 2015
A. Hi Peter. Robert told us that he used an LDC solution for the palladium plating; since LDC specializes in brush plating, I'm quite confident that the palladium plating solution can be applied by the brush plating process, and I already know that the rhodium can be. I suggest you contact Liquid Development Corporation and inquire of them. Good luck.
December 2015
Ed. note June 2016: LDC was bought out by Sifco.
