Chrome contamination of nickel plating bath
Our company produces galvanic nickel deposition.
In our nickel bath we have nickel sulphate, nickel chloride and boric acid.
Did the concentration of 10mg/l chrome reduce the cathode efficiency?
Which other problems can we have with chrome in nickel bath?
When yes, how can we remove this chrome (with methods and chemicals) to have no problems with the normal deposition of nickel?
- Langkampfen, Tirol, Austria
A very small addition of sodium thiosulphate ⇦ this on eBay or Amazon [affil links] will reduce the chrome to trivalent and it will cause no problems thereafter.
A small amount of sodium thiosulphate will work,as Jeff has stated but if you don't want to go the chemical route you could filter it with a fresh filter & a good carbon pack or another way to go is with an ion exchange unit,that will take nickel out of chrome as well,but it is not meant to be run for long periods because eventually will start taking the chrome out of your bath.
Best Regards,
- Scranton, Pennsylvania, U.S.A.
