FRP Coating on a Painted Surface
Dear Sir,
We are coating an Mild Steel Surface with FRP or flakeline coating.
The problem is that the Mild Steel Surface is coated with zinc dust this on eBay or Amazon [affil links] ?
Whether required adhesion as compared to a Bare mild steel surface can be achieved?
Regards...
Kiran Rane
Fabrication - Mumbai
The best person to answer that question is technical services for the company that manufactures the material as they are all slightly different even tho they are similar.
