Electroless through hole plating on pcb
Hi..
I am newbie in finishing metal..
How to do through hole plating on pcb, I need the tutorial.
thanks
Rifqon electronic - Yogya, Indonesia
There is a lot to it, Faziri. For the tutorial I'd suggest starting with Coombs' Printed Circuits Handbook ⇦[this on Amazon affil links]. Good luck.
That, and you buy the latest and best proprietary plating solution for the greatest possible success. Home brew will work for less than 1% of new people.
James Watts- Navarre, Florida
