Bronze grave markers and copper sulphate degradation
Please help. how do I remove copper sulphate ⇦ this on eBay or Amazon [affil links] from a bronze cemetery plaque. Thank you.
Glenn Howardvacation properties - Florida Keys - Key Largo, Florida, USA
Try 5% ammonium citrate(mix 50 gm citric acid ⇦ this on eBay or Amazon [affil links] and 1 lit water + add some ammonia,pH must be 9).If you want you can gel it with some cellulose based paper wall glue(or with agar-agar or gelatin, or even corn starch).Use it only on places with patina, rinse it well after 10-30 minutes,then repeat if needs-after treatment you can lacquer it(with Everbrite [a finishing.com supporting advertiser] or Incralac ⇦ this on eBay or Amazon [affil links] ).Good luck!
