Clear Coating for my Copper Top Bar
I just finished getting my Bar top covered in copper sheeting. I want to maintaing the original shine of the copper rather than to let it Patina. What products are out there that I could use and that can easily be found. Would Varathane, Polyurethane work or will the copper react and distort with those products.
Levi BrownLakeside Process Controls - Mississauga, On, Canada
Try Everbrite [a finishing.com supporting advertiser] coating! Hope it helps and good luck!
I have a copper bar top to coat and was wondering what you used and how it went.
David Bostwick- Essex Junction, Vermont, USA
Levi,
I recommend sealing the copper bar top with a base coat of lacquer followed by flood coat of commercial bar top epoxy. The lacquer seals the surface and allows the epoxy to adhere better. This will give you a glossy bar top appearance that is very durable.
Spring Hill, Tennessee
April 6, 2010
