Thread 436/35
Cracks on the parts which are anodized
I have anodized some Aluminium spare parts and cracks have formed on it. My question is,
1)Is this cracks formed due to the wrong anodizing procedure used or
2) Is it due to the poor quality of the parts or
3) Is it because of a crack which was already there in the part.
4) if it is because of the wrong anodizing procedure, how can we avoid it?
DVD Dealers - Dubai, UAE
publicly reply to Gopinath Rao
Not enough information. With no description of the anodizing procedure, who can say it's wrong?
Possible crack causes:
Sharp edges and corners -- need some radius of curvature, especially with hard anodize.
Flexing of the aluminum substrate -- anodize is about 5x as brittle as aluminum.
Thermal shock. If anodize from low temperature is placed into a hot liquid, crazing occurs.
Surface cracks are found occasionally on extruded material but should be evident prior to anodizing (after etching).
Machining, casting and welding problems should also be evident prior to anodizing.
High residual stress in the aluminum may cause anodize defects, but rarely in my experience. May happen around punched holes in cold rolled sheet.
- Goleta, California
publicly reply to Ken Vlach
