BENDING SPRING STEEL
IS IT POSSIBLE TO REBEND SPRING STEEL ONCE IT HAS BEEN USED?NEED TO BEND A PIECE WITHOUT CRACKING AND SILL RETAIN SPRING.NEED TO BEND A PIECE ABOUT .091 THICK,SLIGHTLY BEVELED WITH A 2.00 HOLE IN CENTER. ANY SUGGESTIONS. THANK YOU,
GARY L. ROLLINSMETAL REPAIR - WATERBURY, Connecticut, U.S.A.
Springs, at least quality ones, are designed to bend and recoup. So, technically speaking it is not possible. What you should do is to soften the steel (anneal), bend it to a new shape and re-harden it again (quench and temper). Not easy. You need a temperature controlled oven.
I have a landscape rake on my tractor and one of the tines is bent up and not contacting the ground. how do I bend it back to shape without taking the spring out of it?
Joe Miheve- Danville, Virginia USA
October 20, 2010
