Checking method of silver plated ss strip
Sir we are a manufacturer of iron thermostats here; we have used ss strip with silver plating. I want to check how much plating has been done but it's very difficult to check with micrometer so please tell me some other method for checking this plating.
Abhay Sisodia
- Delhi
Abhay,
Most companies use a coating thickness measurement device. The most affordable device I know of would be the Beta Backscatter with a silver standard. The supplier would have to know the underplate or the substrate metal under the silver. There are a number of suppliers on this website that can provide the proper unit. Good Luck!
Mark Baker
Process Engineer - Syracuse, New York
XRF Coating Thickness Analyzer
x_ray_thickness
X-ray fluorescence may work very well for this application. However - not cheap. You could use it for other purposes also.
Terry Tomt
aerospace - Auburn, Washington
Dear Abhay
You can use Portable XRF also.
Manuj Kaushesh
- KolKatta, India
July 9, 2008
