My $16,000 engagement ring is turning my finger green
Q. I have a 14k gold diamond engagement ring, I have tried clear nail polish but it only lasts a couple of days. At first the green was only a little, now its all the time. I had this problem in the past with a gold pendant and the clear nail polish worked. Probably because it did not rub as much as the ring does and did not get wet as often as hands do. I wanted to know if anyone has tried to switch to white gold and if they still have the problem.. Silver does not seem to turn green on me. Thanks in advance for any suggestions other than clear nail polish...
Stacey Pilla
administrative assistant - Newmarket, Ontario, Canada
A. It sounds like you got a 14K gold where the alloy material was mostly copper.
The ring was not cheap, so the store that you bought it from made a bundle on it. Talk to them about having it reset in a gold with far less copper in it.
If you search this site, you will find that a lot of unhappy people were sold yellow gold that was rhodium plated. If you go the white gold route, tell them that you want a certified assay of the white gold and it has to be one that is cut with platinum. It will cost more, but it is great. You might get by with one that is cut with cobalt which is much harder, so should wear better.
If you do not mind white gold color, you could have it plated with rhodium for a few dollars. It will last from a couple of months to a year before needing replating.
You might want to take it to a jeweler that makes his own settings, where I think you might get a better and thicker plating job.
Q. When I'm stressed and only when I'm stressed, all my gold rings turn my fingers green. My rings are from all over the world Dubai, Kosovo, Canada, some of them are very expensive and some are not, but they all turn my fingers green when I'm under stress. Does anyone know why this is happening?
Christina Wallis
Retail - Canada
! My white gold ring does the same! I have heard it means you are not eating enough iron, but I don't know.
Cindy Parker
- Boise, Idaho, USA
A. Pure gold, known as 24 Karat gold, is very soft and has poor wear resistance, so to harden it jewelers add different amounts of other metals such as copper, nickel, silver etc. The more "other metal" they add, the harder it becomes, but it also becomes less pure and cheaper. It will also change the colour of the gold. Pure gold is a "golden" colour and this cannot be changed - it is a simple fact of nature. Gold that is not "gold coloured" is not pure gold - fact. Anyway, the presence of other metals will affect how the jeweler's metal reacts on the skin. Luckily most people do not react adversely to most metals, but some do. The most common problem is with nickel and this can cause "nickel itch", which is a type of dermatitis. In an extreme case this can become a severe allergy and has been widely discussed on this site. Anyway, the way this happens is by the secretions from the skin attacking the metal or metal alloy.
The most common secretion is sweat (aka "perspiration" or "glowing") and this contains a myriad of chemical such as salt (sodium chloride) and acids such as lactic acid - it is these, and other, chemicals that make sweat smell the way it does. Unfortunately when the sweat attacks the metal, it dissolves it to give new soluble chemicals, many of which are coloured. in the case of copper, the colour is usually green or blue, whilst nickel will give green colours. This is why your skin turns a different colour - it is due to the dissolved metal salts being absorbed onto the skin. Unfortunately, sweating is increased when people are under stress; this can be caused by numerous factors such as anxiety or physical exercise. Consequently, stress causes sweat, causes colours....
thumbs up signI think Trevor did a great job in describing gold alloys and the effects on the skin. I think his response should be well regarded and respected by readers on this site. If I had posted the inquiry, I would have been grateful that someone had taken that much time to help!
Mark Baker
Process Engineer - Syracuse, New York
A. Pure gold is 24 carat. 14 carat gold contains only 14/24 gold.That is - not much more than half.
I do not believe that Canada and certainly not USA have a hallmarking system. You only have the jeweler's word that it contains even that much.
The weight of an average ring is less than 10 grammes so the gold content is about 5 g with a current value of about £25 or $60 Canadian.
To be worth $16000 that must be some diamond!
If you want to spend that sort of money on a ring, consider spending some of it on a cheap flight to UK. We have had a hallmarking system since 1327. Every piece of jewelry offered for sale must be assayed and marked with the makers name, assay office, date and purity.
Until 1773 the penalty for selling gold at less than the marked purity was death. Sadly, it is now only 10 years- standards are falling! We would also expect a quality ring to be 18 carat.
Geoff, I'm not sure where you get your conversion rates, but I will willingly trade US dollars to Canadian dollars using your rates! The current dollar exchange rate against sterling is 1.92 and 2.27 (US and Canadian) to the pound. Or is gold much cheaper in the US than in Canada!
Trevor
I used XE.com and converted £25 (GBP)to $56.7 Canadian and was guilty of a little rounding up for simplicity. The £5/g of gold is also an approximation. I know there are two price fixes each day on the LME (London Metal Exchange). I used to plate about 50 Kg per year of the stuff.
Where did you find a reference to US $ ?
I'm not sure this [the cost conversion factors] helps the lady with the green finger.
... Just wanted to follow up, I appreciate everyone's responses I have printed all your responses and I am taking it to the jeweler who made my $16,000.00 GREEN FINGER TURNING RING so frustrating as I can wear silver and stainless steel and my finger does not change in colour. I have recently used Witch Craft clear nail polish that seems to give the longest wear before the colour reappears on my finger lasts about two weeks.
For Valentine's Day I received a Silver Bracelet instead of gold as my boyfriend is playing it safe. I will let you all know how it turns out at the jeweler in the next little while. Thanks again.
Stacey Pilla [returning]
Q. I think that there is another problem. I just found this site because I am looking for answers for a friend. She has a white gold engagement ring that she has been wearing for 30 years without a problem and, on the other hand,a yellow gold set that she has also worn on a daily basis for decades. Just in the past month or so both have begun to turn her fingers green--which never happened before.
There is no question both are quality rings.
I have never heard of this happening to anyone else before.
Buffie Griesel
- Loveland, Colorado, USA
Q. Hi there. We purchased a 600.00 diamond chip ring from a outlet store. It is not marked 10,12,14,18, or 24 kt on the inside of the ring. It is turning my ring finger, and the pinky next to it green. I have not had this problem in the past. Isn't it law that solid gold rings, have to be marked? I have worn 10k gold rings before, and this has never happened, this is why I worry! Please help me with advice on this! Thank you in advance!
Carrie Wray
- Springfield, Oregon, United States
A. YES! Gold has to be hallmarked by LAW in the USA. 10k, 14k etc. If your ring is not marked, it is likely gold plate which can be sold and marked as a "gold ring". ALWAYS look for the hallmark!
Grace Face
- Providence, Rhode Island, USA
September 6, 2010
A. I have no idea how true this is... but a friend of mine used to have the same problem with her fingers turning green from her gold rings, she found out that it had to do with her being anemic.
Teresa Berry
- Haskell, Oklahoma USA
January 17, 2011
A. It could be fake. Real gold and silver should not do this to your skin. A mineral deficiency, such as iron, could not be the cause of this. Having a mineral deficiency such as iron will cause a craving for ice.
Dr. Kayla Hernandez
- Houston Texas USA
July 13, 2014
! I had trouble being anemic my whole life and when it's really bad, gold does turn my skin color. It looks more black to me then green. And I know that my jewelry is a great quality because I have family in the business. Only buy the best, quality over quantity.
Lindsay kay
- St. Cloud, Minnesota usa
April 24, 2015
Plated ring bought at 14 kt price. Was I Duped?
Q. I purchased a vintage ring from a consignment shop and paid for the ring as though it was 14K yellow gold and precious stones. I had to have the ring sized and upon the ring being returned to me it came back the color of a new penny. I have photos of before the sizing and after and the metal is clearly a different color. I took the ring back to the consignment store to show and the response was "maybe it was plated". I have 2 thoughts, how does a plated ring get sold for 14K price? And when the ring was sized why didn't the jeweler inform me it was plated? At the very least, allow me to make the decision to invest in a piece that might not have that kind of value? There are no markings at all that I can find in this ring. I would love to hear your thoughts on this, appreciated in advance.
Michelle Alyce
Buyer - Folsom, California
January 21, 2016
A. Hi Michelle. There may be exceptions, but in general if there isn't a karat mark, it probably isn't gold. If, despite lack of markings, something is represented as karat gold, you should probably get something in writing before buying it. I doubt you'll find a small claims court arbitrator who will take your side -- but who knows, especially if the consignment shop operator doesn't challenge your recollection of events.
I don't want to be unsympathetic, because I understand the double whammy you've suffered, but I'm not sure what debt the jeweler ought to feel to you. He may not have known it was plated without spending time and money conducting tests that you didn't ask for or pay for. I'd probably ask the jeweler to gold plate it at his cost if you still want it despite it not being gold. Good luck.
January 2016
Q. My boyfriend recently bought me a beautiful ring. He left the tag still on it and it said 14k diamond ring/1ct/6gm/ctw and the price was on it. It wasn't a cheap ring at all. He told me the person at the store said the band is white gold. I've been wearing it now for 4 days and I just noticed that my finger is slightly green. What could be the cause?
Alieshiea clifford
- Sacramento California usa
April 29, 2016
A. Hi Alieshiea. It is 14K gold so it's hard to say why your finger would get green beyond what is already said on this page. The other markings have to do with the diamonds (1 ct main stone, 6 gm total diamond weights).
April 2016
A. Is anything happening to the ring? If not, may be your boyfriend brought an undersized ring !
H.R. Prabhakara - Consultant
Bangalore Plasmatek - Bangalore Karnataka India
May 1, 2016
A. Hello Alieshiea, as you may know white gold is alloyed with other metals to give the ring a white color. Common alloys are copper, zinc, nickel, silver, palladium, or manganese. There is a very good chance that you have a nickel allergy, even though the nickel alloy is minimal. I would go back to the jeweler and ask what alloying metals are used in the ring. You also want to ask if the ring was plated with rhodium. Most engagement rings are, but not all.They will have to contact the maker of the ring to answer your questions. If the ring was plated in rhodium there isn't much you can do. If it wasn't the jeweler may send it out for rhodium plating if they want your future business and you complain enough. Good luck to you.
Mark Baker
Process Engineering - Phoenix, Arizona USA
May 2, 2016
Q. I have had this problem for many many years. There is something being secreted in my sweat, that when I mop my forehead with a cold, wet, white towel, the towel turns a shade of green. I have eaten thru the backs, and the bottom of the stems of gold watches, it wears thru the bottoms of gold, and silver rings turning my fingers a greenish black. I have found that the only thing I can wear is stainless steel, titanium, or tungsten. Any ideas would be appreciated. Thank you.
David White
- Lomira, Wisconsin USA
June 24, 2016
Q. Hi I just purchased a 9 kt solid yellow gold belcher chain necklace. I've worn it for 2 hours and already my neck is green.
Do you think perhaps if I went up to a 18 kt it wouldn't tarnish my skin? As I've been wearing 9 kt yellow and white gold Singapore chains with no problems. I do want a yellow gold belcher not a white gold.
Many Thanks
Jack
Jack Krueger
- Toowoomba, QLD Australia
August 8, 2016
A. Hi Jack. Is it practical to have it gold plated or clear-coated or both in sequence? Plating with 24 kt gold should be relatively inexpensive and completely stop the greening for as long as the plating lasts.
August 2016
A. Any gold turning green or black means alloys not good from mixing alloy. I have I mixed my own alloy, never ever colour becomes green or black.
Yes, 18K Yellow or 14k Yellow or 12k/10k/9k Yellow Alloy not good; they make green or black -- nothing too do with your body having too much acid. Also same thing in white Gold or silver. Fine Gold is 99.99; 18k is 75% fine gold, adder must be silver and copper + have adder metal. Same thing white Gold you mix palladium; you must know how much adder metal, what to mix. They are like family of metals. You mix wrong and it will create problems; same thing in platinum. You cannot mix zinc, not in my opinion.
Hovannes Parizian
Parizian Jewellers - Sydney Australia
November 11, 2016
Q. I purchased 18k yellow gold bracelet in Italian gold coins. Had it drilled through to see if yellow gold throughout or metal plated. Turns out the coins are solid yellow gold, not of other metals. Great buy I think. But I noticed recently my skin turning blue-ish black wearing them 24-7. If I pull it off, it takes about an hour to disappear. Can anybody relate?
Ozzie Salvatico
- Wildwood New Jersey
January 1, 2017
Q. Hi. I'm hoping someone can help me figure this out. So, a few years back my boyfriend bought me a 14k rose gold necklace and heart pendant from Kays. I have been wearing it every single day since he bought it for me. A year ago he bought me a 14k rose gold promise ring from Kays which hasn't left my finger since except to clean it. This christmas he ordered me a custom 14k rose gold pendant and chain from his family's jeweler. She has been their jeweler for 25+ years and she has a very high reputation.
Unfortunately, this necklace is turning my skin black/green and I can't figure out why. At first I thought maybe it was just some polish left over or something but, no, every day and I take it off to shower and sleep; I just wear it during the day. It doesn't cling to a magnet so I don't think it's fake but I can't figure out why all my other jewelry I don't have a reaction to except this one. My finger has never turned color; neither has my neck with my other necklace. My boyfriend is really upset because this one was really expensive and I don't want to accuse her of bad jewelry but I have cleaned it with alcohol and a jewelry cleaner and NOTHING ... skin is still turning color.
Any knowledge would be appreciated. I don't want to accuse her of something that's out of her control but I'm so self-conscious of people noticing my skin that I don't want to wear it, but he paid so much money for it. Also I have a few rose gold watches (Marc Jacobs/Michael Kors and Fossil [affil links] ) and although those are fake, they don't turn my wrist green even when sweating heavily in them.
Someone please?
Also everything I own is stamped with 14k but this new one also has a stamp "FJ" I think? maybe its nothing but the makers mark but just curious if this is anything significant.
keahi po
- Honolulu Hawaii USA
January 5, 2017
A. Hi Keihi. Rose gold is made rose colored with the addition of copper, and that may be why the alloy is turning green on you. I suspect that this necklace would not be clear coated whereas your less expensive jewelry probably is. I think you should talk to a jeweler about whether it is practical to get a clear coat on it so that it is the clear organic coating that is touching your skin rather than the gold-copper alloy.
January 2017
A. You may be anemic and not know it. I only wrest 24k gold from the Middle East and my gold turns my skin green. I know 100% there is nothing added to the gold because I wear my moms wedding bracelets and they haven't changed color on her in 25 years. When I wear them it turns green. Same with my other gold when my sister wears it she's fine but when I wear it it turns my skin green. I have really low iron and fiber. Check that before you go to the jeweler!! Real gold can turn green, doesn't always mean it's fake!!
Roma Kakar
- Dallas Texas US
January 15, 2017
Expensive new gold rings discolor my fingers
Q. I recently had my old wedding and engagement rings made into new rings for my 25th anniversary. The London-based jeweler designed 3 stackable rings and had them cast in 14 kt gold with my original diamonds and other gemstones. I asked if she wanted to use the gold from my original rings - she declined.
The rings, costing a total of $5000, discolored my fingers immediately. This has never happened to me and I wore my gold rings every day. She admitted that the alloys in her gold mixture were doing this. She sends out for casting.
She offered to plate them for an added cost or to remake them for a slight discount (essentially the same price) I am shocked that she won't re-set them with either my gold or higher quality since she reaped profits with cheap gold and used my original gemstones.
The UK does offer consumer protections - do I have legal recourse? The rings as is are not wearable and I refuse to pay for new ones.
Mary Jo Viederman
Communications - Washington, DC
February 28, 2018
Q. Should a gold ring have a 24k stamp on it if it is an 18k ring?
Michelle coffey
- Ireland dublin
July 10, 2019
A. No.
July 2019
