What prevents nails rusting?
Q. I'm in 8th grade and I am doing a project on which household substance can prevent rusting. I'm using nails to see if it works. I already have oil, petroleum jelly, and I think that is it to see if it works. I need help on 2 things:
1. what else I can use
2. what can help me understand about this topic and not using big words
Student - Chicago, Illinois, USA
A. If you have done any homework (research) on the subject you know that it takes iron, moisture and oxygen to get rust. - Navarre, Florida 2006 A. Fazara, Process Engineer - Syracuse, New York 2006 |
A. You should look into polishing those nails. Use sandpaper from 400 grit all the way to 2000 grit and then use coarse to fine 00 steel wool ⇦ this on eBay or Amazon [affil links] from a Hardware store. Do limit your thinking.
You're in 8th grade, you should be looking at how to anodize pieces of metal. There is a way to do it without buying expensive Chemicals. It's a really easy process to do. Just look up How to Anodize". There may be a topic here! John Fletcher- Durham, NC, US 2007 Nails are usually made of steel, John, and steel can't be anodized. ![]() Ted Mooney, P.E. Striving to live Aloha finishing.com - Pine Beach, New Jersey 2007 |
A. Simplest way to prevent rusting is to make liquid formulation of wax + acetone
⇦ this on
[affil links] Warning! highly Flammable!
+ melamine resin. Take the acetone in excess to have a liquid state of formulation, dip the nail for 2/3 min in this and take it out , the acetone will evaporate and the wax+resin may make a thin coat.
Try with several compositions of the formulations.
- New Delhi, Delhi, India
