Nickel plating pretreatment
Like to know, what is the best pre-treatment for this material NdFe Grade N42SH
which require to plate NiCuNi at 18 microns for electronic industries.
Arthur Koo
Plating Shop - Hong Kong
It will be easier to give you a correct answer if you will give the composition of the alloy.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Sara,
Composition of this alloy NdFe Grade N42SH consist of neodymium (Nd) 30%, Iron (Fe) 66% and Boron (B)1% . Hope this help to answer my question.
Arthur koo
- Hong Kong
