CORROSION RESISTANCE CHART FOR HASTELLOY
Dear sir,
For plate type sea water cooler, what are the disadvantages of using HASTELLOY for plate material.
The sea water temperature is 32 deg C.
The maximum temperature of the liquid for cooling is 90 deg C.
Similar cooler will also be used for condensing propane/Butane gas. Maximum gas temperature 130 °C. Condensing temperature is 32 °C.
Appreciate if I could get corrosion resistance chart for HASTELLOY and titanium.
is a comparison table for above 2 material is available?
Best regards,
Ramesh Kumar
Ship manager - Mumbai, India
For data on the various HASTELLOY® alloys, see the manufacturer's website: http://www.haynesintl.com/
For corrosion data on titanium, see Timet's document: http://www.timet.com/pdfs/corrosion.pdf
Ken Vlach [deceased]
- Goleta, California
