Lapping of ground parts
We manufacture loose needle rollers made of high carbon high chromium steel and perform the last operation (lapping or polishing) to remove few microns and improve the surface finish of the component.
Kindly advise the most appropriate material/compound that should be used for the above process.
Mohit Kapoor
Manufacturer - New Delhi, Delhi, India
If we don't know what are you using now that is not working well, how can we suggest an alternative?
Guillermo Marrufo
Monterrey, NL, Mexico
