  Thread 433/00
Supplementary coating on Zinc Blue passivation
Hello
Can anybody help me? We have sheet metal parts which are Zinc Blue passivated.We need to provide a supplementary coating to increase the resistance to corrosion. One of the suggestions is to use Molybde num Phosphate coating.Unfortunately this is not easily available in India. Can anyone suggest an alternative supplementary coating.
BHUDEB MUKHERJEE
Electronic Equipment Mfgr. - Bangalore, KARNATAKA, INDIA
publicly reply to BHUDEB MUKHERJEE
Hello
To increase corrosion you can go for good Trivalent chromate available in the market.Other wise you can use sealant to increase the corrosion with your existing chromate whether Tri Or Hex type. Contact plating chemical manufacturer or supplier.
p gurumoorthi
P. Gurumoorthi
electroplating process chemicals - Chennai, Tamilnadu, India
publicly reply to P. Gurumoorthi
