Cleaning fingerprints off of copper sheeting
Q. I am using copper sheets as a top on a kitchen island. Want to have it patina naturally, then seal it. My problem is that it has a TON of fingerprints on it, and I don't know how to get them off. Any help?
Nicole Mangin
do it yourselfer - Rio Rancho, New Mexico, USA
A. I think a cleaner that relies on an acid principle rather than polishing would probably leave the copper in the best condition to grow a patina. I play with most of the cleaners and polishes that people mention on this website, to get a feel for them. Revere Copper Cleaner this on eBay [affil links] cleans tarnish instantaneously without any rubbing and, although I think it leaves a slightly salmony appearance compared to the warm glow of Brasso this on eBay or Amazon [affil links] or Mothers Mag & Aluminum Polish this on eBay or Amazon [affil links] , it probably leaves the copper more active and inclined to patinate than most polishes would.
Let us know what you find out.
A. If you want brown look you can rub it with some boiled linseed oil this on eBay or Amazon [affil links] (very,very sparingly instead linseed you can use any other edible oil or fat) and then heat it with hot air gun or gas burner(only backside).Hope it helps and good luck!
Q. Thanks I'll try it and let you know, by the way, how do I remove the excess flux from this same copper sheeting? Some of the seams are burned and turning green and black.
Nicole Mangin [returning]
A. You can remove fingerprints with ammonium citrate solution (5%, pH9, take 50 gm citric acid this on eBay or Amazon [affil links] , 1 lit water and add ammonia this on eBay or Amazon [affil links] to pH 9) ... 5% citric acid can be used too. Object must be well degreased (with acetone this on eBay or Amazon [affil links] Warning! highly Flammable! or pure alcohol). Standard flux remover is 10% sulfuric acid solution. Hope it helps and good luck!
Xylene
xylene
A. This is a fairly easy question to answer. Wipe down with Xylene this on eBay or Amazon [affil links] , let it dry, apply Brasso to it and with a small buffing wheel, not only will it take out the fingerprints but will also give it a high sheen.
Brandt Hinton
- Elk River, Minnesota, USA
Q. I have the same question as originally asked. I noticed that many of the answers were on how to clean the copper but can you just remove the fingerprints in that isolated area, yet keep an even finish throughout the rest of the copper sheeting? Thank you.
Myste Dibble
- Port Townsend, Washington USA
November 4, 2018
