The Tarniban Process
How is Tarniban used - is it a dip or by electrolysis? If it is used as a dip, will it adhere to the metal?
Raymond Allyjewellery manufacture - Tamarac
Tarniban is a non-electolytic dip process. Yes, it will adhere to silver plating. Technic is the manufacturer of this product. They can give you all the info you need to know. Good Luck!
Mark BakerProcess Engineer - Syracuse, New York
