Plating of brazing material on copper strip
I am looking for plating of brazing material on copper strip and brazing equipment. Plated copper strip will be pressed and be applied to brazing on other copper strip. I do not have any idea of brazing material plating and brazing equipment. Expected plating is reel to reel or sheet to sheet. Brazing material size will be 60mm * 150mm and thickness of substrate is from 0.075 mm up to 0.40 mm.
Would you give me help?
Thanks in advance.
Sang Gyu Seo(Jerry Seo)
- Ansan City, KyungKi-Do, Korea
Sorry but I don't quite understand what you are trying to describe. You are trying to design a kind of brazing supply or a repair material that consists of a thin strip of copper that you will precoat/preplate with some material that will then make this strip suitable to be used as a material for some kind of induction brazing or spot brazing?
